Thread: MK 2 tub
Old 08-30-03, 03:44 AM   #3 (permalink)
Chris Melia's Avatar
GT40: England Suffolk
Rep Power: 23 Chris Melia is a glorious beacon of light
Re: MK 2 tub
Hi Guys
The differences between the MK1 and MK11 Tubs?
Well that's a good question, there were three models of the MK11
1. MK11
2. MK11A
3. MK11B
From Ludvigsen "The Inside Story Of The Fastest Fords"
The Mk11 started out as a test experiment in 1964 and was never intended to race. Ford got Kar Kraft to modify a MK1 tub to take the 427 wedge engine weighing in at 550lbs. Roy Lunn head of Kar Kraft new that he first would have to make a new transmission the T44 to take the power of the big block.
To install the big block and trans Kar Kraft had to move the seating position slightly forward with a bulge between the seats for the water pump and modifying the ring bulkhead at the rear of the frame. The car had wider wheels which in turn meant a wider spare wheel, which was accommodated in a completely redesigned front end. The congested front end of the MK1 was redesigned and decongested by extending the nose. A new front end structure carried the diagonal braces farther forward at a gentle slope, enclosing the wider, thicker cross flow radiator with a sheet steel structure which provided built in air scoops for the front brakes. There was room for a large single duct up and away from the radiator, and an oil tank for the dry sump engine in the cowl behind the spare wheel. A new extended nose, with pressure relief vents just ahead of the doors completed the first MK11 Ford.
The rear subframe was changed to accommodate the T44 trans and to support the redesigned rear bodywork.
Side note. This version of the MK11 at the Five mile banked Dearbour proving ground with Ken Miles driving was lapping at 201.5mph and was reaching speeds of 210 mph on the straights. When Miles got out of the car he said that that was the car he wanted for Le Mans 1965.
2 Mk11A had stronger purpose built monocoques from Abbey panels made of steel from 0.024 to 0.049 inch in thickness. They weighed 360 pounds and were exceptionally stiff at 10,000 pounds-feet per degree of twist, corrected to a 100inch wheelbase. It was found after testing in Arizona that a shorter lower nose worked better and gave the car an extra 8 mph on top speed and was also more stable. Ventilated disks brakes at all for wheels and small rear deck scoops for additional rear brake cooling were added. The 12 engines supplied for the Le Mans race had power outputs of around 485bhp at 6300rpm.
In addition to the above a sturdy tubular roll cage was added to the cars for extra safety.
3 MK11B in 1967 Ford realised that it needed more power and a revised "wedge" engine
producing 500bhp at 6400rpm and 470 pounds-feet of torque at 5000rpm. In addition to this a lighter tail section as well as wider and lighter noses were also made. On these separate brake air scoops beside the radiator air inlet were illuminated, the air being drawn instead from the centre inlet. This was extended downwards more than before, with sheet metal "plow" picking up air as close to the ground as possible.
Hope this helps
Chris.
Chris Melia is offline   Reply With Quote
