Old 09-07-03, 08:15 PM   #13 (permalink)
Trevor Jones's Avatar
Canada
GT40: Ontario Canada
Rep Power: 6 Trevor Jones is on a distinguished road
Re: Low Engine C of G / Inverted Gearboxes
Hmmm....puzzling. Just putting a protractor to the screen looks like your estimate of 14 degs at nominal ride height is about right.
I assume the centre line of the inboard cv was placed 70 mm below CL of crank. Those angles do look a bit marginal the way you show them.
As mentioned before, if you tipped the rear of the engine up a couple of degrees (around the motor mounts) you could buy a bit back. I don't think this would effect the lubrication efficiency of the engine.
Trevor Jones is offline   Reply With Quote
