Old 09-08-03, 05:37 AM   #14 (permalink)
Julian West's Avatar
Julian West
7 Tenths
GT40: GTD
Rep Power: 14 Julian West has a spectacular aura about
Re: Low Engine C of G / Inverted Gearboxes
Hi Trevor,
Yes, the inboard CV is placed 70mm below the crank C/L, & as you say the engine is level at the moment but could benefit from a tilt.
It's worth mentioning that with the engine placed as in the picture, a great deal of chassis modification is required to get the Trans to fit.
Either the longitudinal chassis members that pickup the lower A-arms would have to be changed from box section to angle, or 'spread' the box section by 40mm each and shorten the A-arms accordingly.
The rear section of the chassis would also need to be modified, but as you know 'only' carries the trans mounts & the rear deck mounts.
Or, a third alternative is to set the crank centerline at 205mm & keep the A-arms as original.
Do you have an opinion as to the effect of shortening the A-arms by 40mm? Would this have a similar effect to moving the top pickup as per yours & Dereks studies?
Thanks for your input!
Julian West is offline   Reply With Quote
