| Re: Building a frame I doubt you'd be able to convince most of the replica manufacturers to give you blueprints for their space frame chassis, even though the existing designs run the gamut from flimsy to bulky to bulletproof. It takes a lot of effort (and money) to design a frame that is strong, safe, rigid and light. There are numerous mechanical engineering software packages available for you to use should you opt to design and fabricate your own. It could be quite a project in itself. |
