| Re: GT40 Australia #27 Thanks guys - the paint colour is Honda Marine Blue from the last Prelude series, made up in 2-pack by Spies Hecker with a little touch of pearl in it.
As to "skill" - there's not much of that around here. All it takes is patience, bloody-minded persistance & vast clouds of sanding dust! Anyone could take the body finishing process through to the primer stage - I think the secret is to add f/glass as required (I went through about 10m of chopped strand mat & 6 litres of resin), do a reasonable block-back with 80 grit, then coat the whole thing with a very generous layer of sprayable polyester resin/filler (eg. Spies Hecker's "Raderal"). This fills all pin-holes (hundreds of them appear if you just run primer over bare f/glass) & gives a uniform surface for the final block-back with 120 grit, then 400 grit. The final trick is to run a light "guide coat" of black over everything & block it back with 400 grit again - this shows up tiny imperfections which you just can not see in primer.
Kind Regards,
Peter D. |
