| Re: Renault transaxle questions Chris,
Congrats on the purchase of the Tornado! I'll second Jaspers advice, Mach 1 is the place to go for transaxle parts & services.
FWIW There are two ways to mate a R21T to a 302;
Either use a R30 bellhousing (now pretty rare) & an adapter plate (GTD or similar), combined with a smaller (V6 capri?) flywheel, Renault or AP clutch cover & plate & I'm not sure which release arm & CRB or Starter motor. This system works OK & has the advantage of a light flywheel & is pretty compact.
OR: You can buy a specially cast 302/R21 bellhousing from Mach 1 that retains the 302 flywheel/clutch & starter. This has advantages of a more suitable clutch & starter motor, but is a little larger in overall size.
Both systems work out at a similar cost. It's probably worth contacting either Tornado or MDA for parts supply.
Hope this helps! |
