| Re: Fuel Magnets - I want to perform some experiments Vic,
Any suggestions we'll gladly do. We can use a fresh spark plug every run, new filter, along with a fresh quart of oil every run. It is cheap and easy to do. While I do understand the effects of humidity and temp the effects are not so large over the variations we are likely to see - 5 F change over a few hours and 5-8% humidity change. That being said I think I'll run it in a closed garage with an exhaust pipe out the window. That should keep things almost flat - much better than the company can hope to see in real life on the cars!!!! At any rate, I think the test will be quite valid. Please send more suggestions!
No, as for spare time there isn't a lot. My wife and I bought a bigger house (and bigger garage) what we move into in March. But, that means my current garage has become the staging area - it is destroyed as a work area.
I'd have to plan for this test, but I can do it. But, you know, some things just "get to you" and you have to put them to rest. Heck, maybe we can publish the results. You never know - we might find out these things work. [img]/ubbthreads/images/graemlins/crazy.gif[/img] |
