2 LITRE QUAD CAM V8
Ian Anderson
I was reading the latestKit Car Magazine and ther is an article about a Quantam with a strange motor but the specs are impressive.
2 litre, quad cam, 40 valves, and producing 302bhp at 10000rpm.
And weight 72kg
It is built by grafting together 2 Yamaha 1000cc motorcycle engines.
Info on the engine can be foound at www.cyclonepowerltd.co.uk
Now how would that work in a GT40?
You would have a serious torque problem at low RPMs in a 2,400 lb. (wet) car. That engine pushes a bike/rider combination weighing about 650 lbs., double that would be 1,300 lbs. It would be a lot like the Honda S2000 at low RPMs (not much quicker than a Miata). It would probably be an incredible engine in a Radical or small Formula Car chassis.
Kevin
Of course it drops the weight down about 300 lbs from a 351W @ 465 lbs. Neat motor. Wonder what the cost would be? Bet it makes a Lotus 7 a screamer. I wonder how it is engineered. Custom crank? How do the attach the motors together?
strap a small supercharger/turbocharger on each and you should be able to get it moving a bit... I'd bet with that little engine in there you might have some extra space for power adders.
John
Hi all -
Saw this one at Autosport this year - different mfr but I bet it sounds great too. In this instance linked to a quaife transaxle.
