| Re: Porsche transmission oil coolers Sorry Lynn, it has been a while, i havent accomplished alot because my milling machine has been busy with other jobs so the tranny is on hold for a bit. I did get some instructions from powerhaus II that i can email to someone if they like, but you do need to take the transmission all the way apart, including separating the bearing plate from the shafts (you need to grind some metal away in 1 corner. I am hoping that by the end of the month, i will have something to show. |
