Needed - Knurled nut on Smih's speedo cable,
Needed - Knurled nut on Smih\'s speedo cable,
Desperately need the cable nut that fits the cable to the back of a Smith's speedometer. I can drive on the tach around town but not on a planned trip from Oklahoma to Michigan.
You guys have saved the day before so PLEEEEASE, one moe time.
Thanks in advance,
Ben
Re: Needed - Knurled nut on Smih\'s speedo cable,
Ben, it looks like you meant to post this thread in the GT40 Parts for Sale forum. I'll try to move it over there.
[On edit: Ooops...I guess I don't have moderator privileges on this forum. I think Ron or Earl will move it for you.]
Ben, there are two common sizes used by Smiths, which size do you need ? These nuts are made up as part of the cable and trapped on, do you have the cable ? Frank
Frank, I need the cable nut pictured to the left below. i can make up the cable but I need the nut. It has an outside diameter of approximately .55 inches (14mm?).
Thanks,
Ben
Thanks,
Ben
I'll try to post pix again.
Ben
