Head Gasket Quiz
flatchat(Chris)
Am interested in what "racers" are using to keep the fire from the water jacket(gaskets??)in small block fords? assuming all tuning is within normal safety parrameters.
10.5:1 Comp/ratio,4-7000rpm for 15 to 60 minutes.
TX
Chris /ubbthreads/images/graemlins/cool.gif
Most aluminum head manufactures specify a specific gasket that needs to be used with their product.
AFR's 165cc street head uses a Fel Pro #1011-2 head gasket on a 1983-93 302.
These are the gaskets I am currently intending using. I understand they can be re-used. The top of the block is machined for O rings. Any helpful comments or suggestions welcome.
Picture showing part number. They are solid copper. These are 93 thou thick.
Here are the O Rings.
Chris
What happened to your old gaskets. Was it a big problem?
flatchat(Chris)
Thx Lee ,they're thick gaskets Huh,you'll need pop up pistons or a 48cc combustion chamber to get some compression
I've had good results with Felpro 1011's-- but we didn't use them in this instance .could be a lean out/to much spark advance at high RPM resulting in a detonation problem?? still investigating.
Jinxed /ubbthreads/images/graemlins/cool.gif
