| Re: workbench tops I've always used regular steel to cover the benches that will take a lot of abuse (transmission building etc) - a little WD-40 periodically and you dont' have a rust problem. Also, while you are doing it, construct it so that you have a slight slant from back to front - weld a small piece of angle steel to the front in a "V" configuration to act as a drain - place a bucket at the "low end" and you have a nice area to clean parts off and the fluids simply drain into the bucket!.
To join pcs of steel, either but weld and grind, or braise (sp?).
hope this helps |
