Old 06-06-04, 04:26 PM   #2 (permalink)
p thompson's Avatar
p thompson
Administrator
GT40: None
Re: Box full of nothing
Oop's - [img]/ubbthreads/images/graemlins/frown.gif[/img]
My guess is a quill shaft breakage - the extension piece on the front of the renault box that passes through the clutch and into the spigot bearing.
Where the shaft necks down is a common failure point.
If it is the clutch, they are available over here - I'm sure Frank Catt or Mark Sibley could help.
Re Engine/Transmission removal as a unit, use an engine crane, sling to balance (norm front of heads to drive couplings) and MIND YOUR BULKHEAD GLASS!! - EASILY BROKEN!!
Let us know what you find...
best regards
p thompson is offline   Reply With Quote
