Old 06-13-04, 02:05 PM   #8 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
Re: Pulleys and brackets
Brian,
I designed a set for my serpantine setup w/AC and had a local shop fabricate them. I used a March crank pulley, T-bird waterpump pulley, Sanden short A/C compressor. The real trick was locating the Powermaster 160amp alternator. The pulley for the alt. clears the heatshield on the firewall by about 1/4". If you use one of the mini high amp alternators that are available now, if should be much easier to fit. I wanted the extra amps for the EFI system, the AC, readiator fans and all the lights I mounted (headlights, driving lights and foglights.) All this makes for a high amperage requirement, but the EFI is really the straw that brakes the camel's back. Unless you are putting in a very high rpm motor, I would suggest that you NOT underdrive the waterpump. That is why I chose the T-Bird pulley: if anything, it slightly over drives the waterpump.
Here is something that is VERY nice to know if you are using serpantine. What ever the length of the required belt turns out to be, if you can find that length with the proper number of ribs OR MORE, you can use a belt with more ribs and carefully trim off the excess ribs. I was informed by serveral manufacturers that these belts are produced with as many 200 ribs and then are cut to the desired width. The pulley that is usually the problematic one is the AC compressor pully. Mine only allows 4 ribs and I ended up cutting down a 6 rib belt to get the proper length.
Guys, I don't know if you've seen Kalun's website, but this guy is a shop wizard right up there with Merlin and Gahndalf. This man knows he can do some fantastic machine work. Kalun, I know you've probaly posted it elsewhere, but post it again so more of us mortals can marvel at your work!
Lynn
