| Re: Electronic vacuum advance? Howard,
As I tried to explain above I did originally have a MSD mechanical only but the engine would not idle unless I advanced the ignition to about 20deg BTDC at static but then I got detonation on acceleration.
I have disconnected the vacuum pipe this w/e and set the timing to 10 BTDC (using a strobe) and it appears to run better on acceleration - haven't got stuck in traffic yet so I'll have to let it idle in the drive to see if its any different now. Maybe I have another problem with the idle other than timing?? |
