Lynn Larsen
Lynn Larsen
Hey all,
My motor will absolute max at 500HP and that was calculated based on a Dart block with 4.125 bore and a 3.25" stroke, but I just bought a R302 and am going to start at .040 over and won't even get to 4.120 for a while and will still use the 3.25" stroke. I'd like to go with the lightest rods that won't break on me. The PITA is that I am right on the edge for going with I-beams or needing H-beams. There will be little to no banging of the engine (read no drag racing), but there will be rpms up to 7-7.5K that the rods should withstand. Haven't decided on pistons yet, but I will use <500gm forged pistons w/ tool steel pins for sure. I've got a shot at a new set of Eagle I-beams for $150 (one bushing will have to be replaced; the guy screwed it up somehow, but at least he was man enough to admit it) which is hard to pass up. But one of the goals of the motor is to make it bullet proof.
So do I go with the I-beams or use the heavier but stronger H-beams???
Thanks,
Lynn
Thanks,
Lynn
