Thread: TYRE SHELF LIFE
Old 07-24-04, 03:35 PM   #10 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
Rep Power: 21 wbmusarra is a name known to all
Re: TYRE SHELF LIFE
You will see the same thing with regular tires as well. Maybe only a slight bow in the base of the tire. My 95 Ram 1500 has the biggest tires alowable on the stock rims which makes it sit a little higher. I towed a "Gator", which is a 1000 lbs. utility golf cart, on a trailer for about 150 miles, after driving the 150 to get it. After arriving home I decided to check the tire pressure all around as the trailer had one of its 4 tires low a week or so ago. For some reason I checked the trucks as well and found one of the rears at about 10 lbs. It didn't look any lower than any of the rest. So looks can be decieving.
wbmusarra is offline   Reply With Quote
