| Re: Stainless suspension bolts ? If you are replacing a grade 5 bolt, a good stainless bolt with rolled threads and a good heat treat should be able to do it, because grade 5 is pretty weak. The required tensile strength is 120 KSI with 14% elongation.
Grade 8 is 150 KSI with 12% elongation. That's very hard to match with stainless.
Elongation is the measurement of the fasteners ductility. As the tensile strength goes up, elongation goes down. A bolt with very little elongation will look good untill it snaps. A bolt with more elongation will strech before it breaks and in that stretch area, the diameter of the fastener will be reduced.
If it were easy to make grade 8 bolts, we would only have grade 8 bolts. We have grade 5 because we needed a spec for the cheaper bolts.
With stainless, the elongation is what kills you, it's easy to find a stainless alloy with high tensile strength, but it's very hard to make an alloy with good elongation. I'm sure some one could make a grade 8 stainless bolt, but it will probably loose some of the corosion resistance that stainless is known for and it will be $$$. |
