| Re: Roush 402IR or Ford racing crate motor? Martin,
I believe it has, but if you go by the "official" specs, it is marginal at best (and that is being generous.) The Pantera guys have put quite a few outrageous motors in front of them, but there are some techniques that should be employed to help the ZF out. That said, I think that one could get a ZF variant from RBT that one could be very comfortable with. These were the first transaxles used in the new Ford GT with 500fp. They have since been replaced, but I believe this was because of production volume concerns and not the quality of the units. I don't know if the Ricardo that replaced it is a viable alternative: I have no clue what its dimensions are. The GrandAm Daytona Prototypes are running Trax and Enco transaxles that are huge and would never fit in a GT40; otherwise this might have been a way to go.
I would lean towards Howard's recommendations myself. To my knowledge a G50/50 or beefed up G50/xx probably provides the most capability/$. I think the only things that should be considered at these power levels are a billet side cover and aux. oiling of the diff, at least, if not all of the gear sets. Beefier shift forks is another common mod that is done, but this isn't really associated with the amount of torque the unit is handling.
Lynn |
