| Re: Split Block ???? Lynn,
If the Dart block is available in a 9.5" deck is it the same as the Ford W351 which are the siamese bore 454 cu. in.?
If so then the intake manifold will be different than a standard 302 and won't there be a height conflict for a GT40?
The reason I ask is because I would sure like to consider that motor PI Motorsports is advertising as the "Hammer". If they wedged it into a CAV, it must be doable. I haven't seen the specs yet on the "Hammer" but I assume it's a tall deck 351w. |
