| ZF Shift Pattern Like it says on TV, trained professionals, please to not attempt this at home! No easy task routing the gear selector down the sill in the CAV. The shift rod travels along the cavity originally provided for heater plumbing which has bee re-routed to the console. Notice the normal H-Pattern is for 2nd>5th gears. 1st is halfway across the neutral gate to reverse and back. On the track, 1st would mostly be used for start and leaving the pits. |
