| Re: Movit Brakes Lukas,
Thank you very much! The last line is the one I was most interested in as I knew it was saying something about the hand brake, Handbremssätteln, but I couldn't quite get the full meaning.
I am presently trying to find the biggest, baddest rear brakes for the 88-90 C4 Corvette to suite the mid-engine arrangement of the GT40 and put the braking power where the weight is.
The de-emphasis of the rear brakes is one of the issues I see with using braking systems designed for front engine cars on a GT40 such as the Corvette system used on several models. The other issue I have is with the design of the master cylinder. I have raised this issue before, but no one has given an explanation of how one should work around the issue. The problem, as I see it, is that the master cylinder has a built in biasing valve to favor the front brakes. In my braking system, another biasing valve is placed on the front brakes line to counteract the built in biasing valve. This seems counterintuitive and counter productive to me and there ought to be a better way of doing it than having two mechanisms fighting each other.
I would appreciate any comments from anyone even if it is to say you agree or disagree with my concerns. Obviously, I would love to hear from someone who might think they have a solution to this perceived dilemma.
Thanks,
Lynn |
