Thread: My Jesel Saga
Old 11-19-04, 03:04 AM   #13 (permalink)
Kalun_D's Avatar
Kalun_D
5 Tenths
GT40: KVA body, scrat
Rep Power: 10 Kalun_D will become famous soon enough
Re: My Jesel Saga
Well the Pro Magnum rockers are installed and the tips still won't center, except it's only on some of the valves. AFR says to put some ARP studs in it, this helps because their longer but the stud holes are still a little off on some of the valves. This confirms what the machinest says that ARP uses some economy hardware. The ARP studs definitely improve the centering buts it's still not exact.
I guess I didn't know what to expect with mass produced A.M. heads. The tips are also off center in the front to rear direction also. Measuring the distance between studs shows a .025" max difference. A straightedge from front to back shows a .015" difference. The threaded stud holes are inserted with heli-coils which I've never really liked, and think this may be contributing to innacuracy.
The cam is also showing off time by up to 6 deg between different valves. Need to do more measuring and researching and may post to "engines and drivetrains" once I have it all figured out.
Kalun_D is offline   Reply With Quote
