Old 11-29-04, 08:32 AM   #9 (permalink)
ross nicol's Avatar
ross nicol
Re: ZF Shift Pattern
Frank, thanks for confirming my observations.I, like you don't have the ZF selector shaft box.However I have the genuine ball on the cross shaft, and have fabricated the rest.I've spent quite some time comparing a stock selector shaft box( on loan from a friend )to mine. The fore and aft movement is the same but because the drop shaft is longer this translates to more lateral movement at the stick.I'm going to make a box exactly to the original, which only leaves the stick ratio to sort out.Do you have the same setup as Ian? I want a short throw shift with some mechanical advantage. My shaft alongside the seat is about where Ian's is so a stick with similar height will be ok.Is yor setup the same Frank with uplink to rodend? If so can you give me details of it please.
Regards Ross
ross nicol is offline   Reply With Quote
