Old 01-29-05, 01:56 AM   #5 (permalink)
Phil's Avatar
Phil
3 Tenths
GT40: scratch built Mk1
Re: Suspension Design
Eric
Kalun makes a great point when he says stick to the basics, that anti-dive you have on that boltup which looks like the upper wishbone looks really excessive. But considering the front end weight and weight transfer on braking it was really necessary, and a compromise at best. Also keep in mind that if you set up that much anti dive in a chassis that doesen't require it that will also cause handling problems. The anti dive is meant to keep that front end as close to ride height as possible, and I think you need far less, that would simplify your mounting points.
Good luck
Phil
Phil is offline   Reply With Quote
