| Re: New front suspension for my RF CORRECTION
""It's a shallow angle on the front rod end so you probably can't do what you did on the rear one with a separate piece. Might be easier to bend the front leg.""
Should have read......
It's a shallow angle on the rear rod end so you probably can't do what you did on the front one with a separate piece. Might be easier to bend the rear leg. |
