Old 28th February 2005, 12:58 PM
Howard Jones's Avatar
Howard Jones
Gold Supporter
Re: Brake options for Corvette C4 85-87 Hubs
Wilwood does make a rear rotor with hat that is made to fit a corvette. They also make a two piece rotor/hat combo to fit a corvette. These use the corvette e-brake parts and has a drum brake inside the hat just like the corvette.
This way you would be able to run any 7inch diameter X 8 hole rotor bolt pattern. This will allow you to run a lot of different rotors. You could then select a different brand caliper if you don't like wilwoods. If I was doing mine again I would use the forged superlight 3 caliper from wilwood on all four corners and 13" X 1 1/4" up front and 11 3/4" X 1" on the rears.
I left the e brake off my car. Not worth the extra hassel and cost. Also the little spot calipers have been known to slip on sloped driveways. Beware these little go cart calpiers.
Howard Jones is offline   Reply With Quote
