Old 04-05-05, 06:04 AM   #3 (permalink)
Fatal Attraction's Avatar
Fatal Attraction
GT40: Ex-DRB #35
Rep Power: 23 Fatal Attraction has a spectacular aura about
Re: Bolts and washers ?
Frank,
That's ridiculous! A flat washer, beneath a spring (lock)
washer? The added compression of the lock washer will
keep the bolt AND the two washers from rotating. The flat
washer only gives the lock washer a FLAT surface to grab
onto, it doesn't reduce the lock washer's effectiveness.
I don't think the tang has much effect on whether the
bolt will come loose or not. Once fully compressed, compression
is at work , not the tang biting into the flat washer or
the bolt head.
If it weren't for your friend's misfortune,
I'd think this was a joke!
Has this SVA engineer ever worked on a car before??? In the
engineer's opinion, what would have been the "PROPER" way
to secure the cover?? Spring washers with no flats?
In his defense(not really!), I have seen plenty of "factory
bolts" on engines, etc., without flat washers, where I
thought there should be one.
Perhaps there are supernatural forces involved here, that
we mere mortals are unaware of? [img]/ubbthreads/images/graemlins/tongue.gif[/img]
Fatal Attraction is offline   Reply With Quote
