Old 04-07-05, 10:35 AM   #41 (permalink)
nota2266's Avatar
nota2266
GT40: Kurrajong, Australia
Re: Bolts and washers ?
Very true Paul, you may notice that in an earlier post I said that in some instances I used Mild Steel bolts, this is purely so the bolt can be proofed correctly where using a higher tensile bolt and higher torque to proof the bolt results in damage to the components being fastened. I also use them in some areas where it is better for them to bend rather than break (if you hit something !!)
nota2266 is offline   Reply With Quote
