| Re: Electric water pump otions, looking for opinions No heater, if there's a defrost problem I'll divert some air from behind the radiator and put a round duct vent fan.
The optimum setup for a heater is right where the main tubes come out of the front of the center tunnel.
Right where they turn out of the center tunnel, so the flow goes straight into the heater hose. So like the main pipe turns and the heater pipe goes straight off the turn aligned with the tunnel part of the main pipe.
That way it gets flow without a separate pump and doesn't have the extra lines in the tunnel.
When I get time I'll draw a pic. |
