Progress of the giant - One Off Large GT40
Honnycomb panels. This will hold 4800 pounds where the driver sits
Re: Progres of the giant
foot room 11EEW
ajustbul peddels and colum
exsost smog leagle in CA
custom power for neutral geometry. We had to have a custom rack because the car is larger and we wonted it to have a short turning radius . And a power rack and still be under two turns lock to lock. and with a 19X11" front tire you got to have power.
Right size wheels
We keep cutting. Took a wedge starting at the rear wheel to the front wheel. And 1" out of the nose
Dave Allen of McKenzies spent a few days with us and showed us how to properly set up an axle. This is a bigger setup than is in the Saleen that he also builds.
a hydra boost 25,000 psi
The motter shrunk
Drive train is complete and a custom set of wheels wiring and plumbing and it will be a runner
The fans above are 2950 CFM each and draw nine amps each they are 16". the radiator is 38"x 20" the condenser is 19"x 36"
WOW, F.A.N.T.A.S.T.I.C......
May be at our next gathering in Cali, you can drive this beast up. /ubbthreads/images/graemlins/cool.gif
