| Re: Heat Sheild for Webers Hi Bill,
There's a computer cut stainless steel base plate between the carbs and the manifold. The sheild is aluminum although sealer was used on the mating surfaces to stop corrosion.
The hole ahead of the center linkage is for the vacum tap. We made a vacum chamber under the intake to suppply the power brakes.
Cheers |
