| Re: Rear Suspension Upgrade Inclination of the hub to introduce Anti-Squat is accomplished by a 1" spacer added to the upper clevis pin. Additional clearance on the lower shock mount from the parking brake caliper also reduces the angle the coil-over lays at. This means less loss of spring rate as the coil-over moves up when you're in bump or on the outside rear wheel when cornering hard. |
