NE1 with a Fuel/Air Meter in UK?
Charlie Farley
Hi,
Im hoping someone may have a Fuel/Air meter in the UK, for hire for a small consideration.
I need it to set up a set of Webers. Any help appreciated.
Ross Nicol
Hi Charlie I've got one but I'm in Australia,not much good to you.One thing though if your tuning webers and running leaded fuel, the lead coats the sensor and ruins it over a short period of time.
Anyone who would hire one is likely to ask this question.Mine runs a heated Bosch wideband sensor and they cost a bit.You can buy a unit or kit from a Tech Edge in Canberra. Mine cost $450,plus my assembly time.Probably not much in Stirling.They're on the net, just put their name in Google.You need wideband by the way don't waste time with narrow band.
Ross
Hi Charlie
I have a Motec Wideband PLM unit, when are you wanting to use the meter? I presume you already have a bung welded into the collectors in an appropriate position...
It's currently hooked to an M48Pro ECU for fulltime mapping but can easily be pulled off and happily works 'stand-alone' with just power connection (GND/12v).....
