| Re: TWM/Weber manifold flow If you take that formula and plot venturi size vs. peak RPM, for a 342 inch motor, this is what you get.
I did it in a spreadsheet so I can vary engine displacement easily and the results are telling. A 289 is very happy with 44mm venturis since it'll go to over 7800, while 347 is not and will peak about 6700 RPM. |
