Old 01-04-06, 02:47 AM   #11 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Re: Front number plates.
I got away with no front plate for a year, but then decided that was enough of asking for trouble.
So I did much the same as Simon, but mounted the plate on 2 very thin bent s/s brackets. The plate stands up at a reasonable angle when the car is stationary, but only takes the slightest pressure to get it to lie down almost flat.
I tried to figure out a way of using hinges & springs, but that all got too hard - hence the "springy brackets".
Whilst I haven't yet got around to getting someone to take a photo at speed to prove it works, I have found that it has made absolutely no difference to the coolant temps at all - even during our heat-wave conditions over the last month or so (over 35degC).
Its cheap & easy (but I do like Simon's friend's approach of the scratched up plate - so cheeky) !
Kind Regards,
Peter D.
delaneyp is offline   Reply With Quote
