| Re: SVA test CAV GT The CAV headlite brackets are marginal at best, I got a newer set from AutoFutura but I still had to shim the brackest to get the adjustment correct. It really doesn"t take very long, I used tubing the same diameter as the legs on the bracket and got the rough adjustment that way and then I was able to use the adjusting screws to finish the job. |
