| Re: Vacuum advance - is it needed? Ray, you might want to look at what the various intake manifolds offer in terms of a vacuum chamber. My 8-stack setup is on a DC&O manifold & it has quite a large chamber built in under the centre section. A bleed hole runs into it from each intake port & it has a couple of vacuum take-off ports on top at the back. I think that TWM have a similar setup under their manifold.
We originally had all vacuum devices running off one of these take-off ports, but found that the ECU was getting unreliable readings when the power brakes got a bit of a workout. This problem was solved by moving the power brake line to the second port on the manifold.
Kind Regards,
Peter D. |
