| Re: Olivers Ride RF with ZF Frank Sorry mate I realize I should have replied to your earlier posted questions.You won't be able to use the Pantera bell housing.My bell housing you can see in the photo is an ERA sourced Item and it has the bottom shaved to be level with the ring gear.It bolts directly to the ZF-2 and allows use of a Standard Ford clutch and flywheel.The ZF can then be mated to a Windsor motor and to set the whole unit low in the chassis you will have to dry sump or get a shallow sump with wings.I can help you with dry sump detail if your still unclear what's required.
Regards Ross |
