Old 03-04-06, 01:49 AM   #31 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Re: Sandy Ganz engine and trans
Very nice combo Sandy.[img]/ubbthreads/images/graemlins/flehan.gif[/img]
What starter have you elected to use with this setup? I presume you'll be running an alloy flywheel with ring gear in the conventional position? Any specifics re starter and ring gear much appreciated. Also a description and photo's of the spraybar setup would be informative, save me reinventing the wheel!
Good luck with your build.
