| Re: Sandy Ganz engine and trans Russ -
Thanks!
The flywheel and starter are from PowerHausII, which are actually from Kennedy. The flywheel is porsche to ford and is steel but I think its weight comes in at ~13 Lbs (~6kg). The starter is also from them for mounting in the porsche housing. I have not seen them as they are all at RCR. For the spray bar, I can't get a pic on that unless the trans blows [img]/ubbthreads/images/graemlins/smile.gif[/img], It has been done and buttoned up by PowerHausII. Sorry can't help with that. For the spray bar you might be able to get some info from Roger at PowerHausII, he may also be able to supply a kit of parts or something.
Sandy |
