Old 4th March 2006, 03:13 AM   #7 (permalink)
ross nicol's Avatar
ross nicol
Re: Proper oil for ZF?
Hi Frank, Please don't hang that expert tag on me but an interesting point you raise.My M1 25-2 that I had the cross shaft housings made for had exactly the characteristics you describe.Because we made the housings I assumed it wasn't normal and the oil drain from the rear of the shaft wasn't big enough hence the hydraulic action.I think we did enlarge the slot in the housing.You could push the shaft in and watch it slowly come out with spring pressure.My new ZF should arrive this week I'll let you know if it exhibits the same characteristic.
Regards Ross
ross nicol is offline   Reply With Quote
