Frank's KVA Build
instead of posting on different topics
starting a new one here
did started on the chassis work for flipping my zf
first cutting away the mountingrack
I'm going to order the bellhousing from john wisher
and make a decision on the engine spec's and order it
Ross Nicol
Re: frank\'s kva
Glad you started this Frank. I've been trying to find the post where you asked for measurements and details on the bellhousing.I think you've already ordered one but here are some pics and measurement for you anyway.
Ross
Ross Nicol
Re: frank\'s kva
oops forgot to shrink it
Ross Nicol
Re: frank\'s kva
#2 Bellhousing is 4" deep
Re: frank\'s kva
i didn't order it yet but planed to do so
here is a picture
got my engine
here's a picture of my engine
stil needs to swap the distributor and get a gt40 oilpan (which one ? and available in europe?)
also busy with my gearbox i did order a set of gasket's for my zf and a top with mounts on it
it has been a while but i've made some progress
almost finished the rebuild of the backend of the chassis
and got some work done on the uprights
Re: frank's kva
Frank
Nice work! Looks like you've made the commitment. I was wondering what you were going to do as far as the rear chassis, supporting the lower wishbones and the decklid. Nice job on the wheels, always a lot of work there.
Phil
Re: frank's kva
Phil
Thanks for the compliment
If all goes well the lower arms should be ready this week
Ive got someone who works at a metalworkshop he does all the things where i haven't got the tools for when they are ready i'll post some more piccs
and for the rearclip it's going to be a system witch i saw by frank catt and i also saw it on some pictures but it's hard to explain it's a quick remove system
