Old 03-16-06, 08:43 AM   #1 (permalink)
steve c
Steve
GT40: SPF GT40 P2125
Rep Power: 7 steve c has a spectacular aura about
Help from CAV guys? re suggestions zf to FE external clutch
Anyone have suggestions re ZF BMW to FE clutch components for external slave set up....has this been done or am I breaking new ground?? I'm all set on the external slave cyl, bracket and linkage to the ZF cross shaft but, need help with the bellhousing/clutch and TOB......want to keep the bellhousing as short as possible...plan to use about a 4.5" long inverted Pantera with a special Mc Cleoud 10.5" flywheel w/ 184 teeth for the FE and a short press plate BUT, dont know what to use for a throw out bearing or how to determin needed TOB spacing for the ZF cross shaft arm...Does anyone have a parts list for this...Any of you CAV guys????? ps...Is the RBT ZF bushed cross shaft reliable (are the bushes sealed, does it work OK, should I use sealed ball bearings instead???) Any and all thoughts w/b appreciated Steve
steve c is offline   Reply With Quote
