Olivers Ride RF with ZF
Ken,
I'm not sure that you had to go all the way to Australia for your manifold. It looks virtually identical to a crossram manifold, built in house, by TWM in California.
Very nice, no matter where it's from!!!!!!! /ubbthreads/images/graemlins/cool.gif
Just curious...will you need to trim the fiberglass around the induction hole, or will the manifold squeeze through there?
John B
Temp Selling Pass
To flip or not to flip??????
Not flip.. Pantera shift patern...simpler install with out the exspensive modifications to the gearbox.
John B
Temp Selling Pass
Larger Master clutch to handle the larger throwout bearing.
John B
Temp Selling Pass
The bell housing is from Kenedy engineering. It is a very nice piece for $350.00. ERA is around $1000.00 more or less. It is alot lower than the flipped version. This also allowed the engine to be lower in the chasis. The oil pan had to shave a litle more so it would not hang over the chasis. It is a very nice fit.
Oliver
Ron McCall
[ QUOTE ]
but you've got a different bellhouse then is fitted to the pantera zf
your's is lower
look's smashing
Frank
[/ QUOTE ]
How can it be lower? The input shaft still has to align with the crankshaft. Correct?
/ubbthreads/images/graemlins/confused.gif
Chris Kouba
That's what I thought too. Assuming same clutch size it would just give more or less clearance (internally) around the pressure plate.
Chris
