| Re: toe Degrees are better, but at the track we use homemade tow plates. Just two aluminum plates with slots and the plates stick out in front and rear of the tire, one for each wheel. Use a tape meausure to measure from front to front, and back to back, the difference in these measurements is the total toe, in mm. Change accordingly. I've got about 2-3 mm tow out each side for the Miatas, but we want turn in and are giving up a bit of straight line stability. Likes turning though! |
