| Re: HP limitations of stock RF fuel system Ross, if I go to AN fittings on the high-pressure side of the fuel system, I'll need a new fuel pump, filter, bulkhead fitting and associated lines. I may end up going that route but I'll probably try the stock system first. May require datalogging rail pressures on the dyno as I tune the engine.
Ian, thanks; I'll have a read through that thread. |
