Old 04-10-06, 08:13 AM   #117 (permalink)
flatchat's Avatar
flatchat
Silver Supporter
Re: GT40 Australia #27
The new short crate will need to be pulled to bits for a proper balance and piston valve clearance machining if you have the big valve heads etc. Reworking a "seasoned" block has advantages if its still under .030" overbore.Otherwise by the time you crack test and lick up the crank,hot tank-deck-bore and torque plate hone the block -- fit new pistons, rings,slippers,cam,sprockets, chain and oil pump --- yeah the costs would be close.
Also recommend screw in core plugs or at least "fix" 'em so they can't fall out--particularly new blocks.
"Felpro"(min.) gaskets a must!
Gooda lucka mite [img]/ubbthreads/images/graemlins/laugh.gif[/img]
flatchat is offline   Reply With Quote
