| air con and other bits in the manual the a/c thermostat (long metal tube from control switch ) is stated to be run into the fresh air vent behind the plenium,is this correct or should it be measuring the temp of the cabin from else where so that the evapourator is controlled accordingly?
the dash wiring loom has a hella plug for a hazard warning light switch,it is a 2cm diameter castlated mount does any one have the part number for the switch?
In the dash loom there is no regulator ,does there have to be one ,~? if so which one?
As you are begining to gather there are a huge number of parts missing from the rare SA cars! but of the ones there the quality is good.Must say a quick thanks to Jerry for his help in part sourcing and to rick chatell for his continued support [img]/ubbthreads/images/graemlins/help.gif[/img] |
