| Re: air con and other bits The tube runs inside the evaporator and against the coils. This cycles the compressor as to prevent the evaporator from freezing(it is reading the evap temp. not the cabin temp)
The hella switch you need is part #5227 hella Au I sourced one on ebay from GB for $25 US 2 weeks ago. It is a commercial application truck, bus etc. My problem was not distributed in the US but I'm sure you can locate near home. |
